Salta al contenuto principale
The LG G Watch R is a Smartwatch manufactured by LG that includes many features of a Smartphone and a full-circle P-OLED display.
26 Domande Visualizza tutte
My watch is not charging at all
My step-dad recently gave me his LG G Watch. He said it's about 2 years and has been sitting for a while unused, but was working when he stopped using it. It's been on the charger for at least 2 hours now, but still no charge. Please help
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
7 Risposte
Risposta Più Utile
You may need to change the battery, see other answers but try a factory reset, while keeping it on the charger press and hold the side button for a minute or so until you see the LG logo then let go, it may then do a reboot. If not - when you get the LG logo swipe from 11 to 3 and you may get a 'bios screen' at that point press the 0 symbol at the bottom of the screen. Odds on it will require a replacement battery I think.
Punteggio 1
please send the photo of charging port.
1'may be charging port is wsated
Punteggio 0
1 Commento:
I'm new to this. How do I send photos?
da
battery need some low voltage shock then it will work
Punteggio 0
1 Commento:
How do I accomplish that
da
I too have a the same problem as the rest of the countless users here on iFixit as well as on other forums including XDA. Even though the G Watch R was the best looking rugged smart watch to be released as the time it seems most shittiest of products. Thumbs down to LG.
My watch worked fine, until it decided to die all of a sudden while on my hand, thought there is no juice left,but even though charging/changing cradles and chargers it did nothing. Pressing the the side button makes the screen blink with the charging battery icon but thats it.
The strange thing is when u leave it in cradle over night, i mean over good 4 or 5 hours left to charge, it decides to come back to life. But stays on only while on the plugged in to power, the moment you take it out same problem, it just dies.
The charging ports are, clean. The side button and touch responds (when it decides to switch on), i even once did a factory reset, also i have removed it and serviced it with 90% alcohol.
Im really really frustrated with this bloody piece of junc, please advice me what i should do next.
Where i live, there is no eBay access, even they do, chances are high it gets stolen in domestic post.
Please help....
Punteggio 0
1 Commento:
I had the same issue, how you fix?
da
I had a problem where if it would charge, it would rapidly switch from watch face to clock motion charge status... it would sit at a charge number then switch back to watch face, then switch back to beginning charge again... and cycle until it was dead...
I ended up replacing the battery, but that alone did't fix the issue. It did start up w/ a charge initially but never fully charged and ended up being a brick again regardless of what button i pressed or did.
I then decided to use a multi port USB charger... I chose the 2200 am charger ports instead of the 800 or so that came w/ the unit... n battery went to charge mode and now fully functional. I may just leave my watch in the kitchen where the charger is instead of up in the bathroom... at least I got a smartwatch back for less than $30... thanks for everyone's posts in troubleshooting.
Punteggio 0
where can i buy lg g watch r battery? i ‘m in malaysia i bought new dock charger but my lg g watch r seemed to be having battery problem. Please tell me where can i get it.
Punteggio 0
1 Commento:
Amazon or ebay
da
Saw the post above regarding high amp charger so I tried my ASUS tablet charger and it’s actually trying to charge!! Will see if it manages to fully charge and then see what happens :)
Punteggio 0
Aggiungi la tua risposta
Michelle Miller sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 9,829
