Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2175 Domande Visualizza tutte
after replacing battery, will not charge,turns on only when connected
After replacing the battery the phone only comes on when connected to wall charger. Battery % at 48% does not change and lightning bolt is on.As soon as taken off the wall charger the phone turns off. Will not charge with usb cable on computer.Can not make or receive calls,no sound.Did Try holding the power and home button until apple logo but no change.Does this sound like the dock connecter/charging port needs to be replaced or could I have done something else wrong when replacing battery?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
It sounds like the battery connector to me. Here is a good video about a similar problem. I'm not sure about the battery percentage though.
Punteggio 1
There is a chance you could have damaged a charging IC when disconnecting the old battery. Its also possible that a charging IC was bad, which led you to believe your battery was bad. I'd bet money on one of the charging IC's being at fault.
Punteggio 0
Aggiungi la tua risposta
mike sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 77
