Salta al contenuto principale
Acer's 15.6 inch E5-571 series laptop manufactured in 2014.
29 Domande Visualizza tutte
Power switch isn't working?
Hi,
My Acer laptop isn't working anymore. When I press the power button, nothing happens. I looked inside the laptop and saw nothing strange on the power switch, also not on the flex. When I 'short' the connections from the power flex, the fan is working and the hdd runs; but nothing on the screen. After a few seconds is turns off. Could it be the power switch or is it something else?
Thanks in advance!
Questa è una buona domanda?
Punteggio 0
1 Commento:
Try taking it to a computer repair shop.
da
Aggiungi un commento
1 Risposta
sounds like there is more going on..
I had the same problem, turns out there was a ram problem to... it had a short circuit and fried the ram.
if the fan starts, there is power. maybe not enough, you ll have to check that. ( measure it out if possible)
than check with new ram.
if still not working :
check with an extern monitor.
Check the flat cable and connection from mainboard to screen.
it is possible the chip on the graphic card is fried..
I was thinking on a dead motherboard , but the fan starts ... so i think more in the other components..
Let us know,
Kind regards
Kevin
Punteggio 0
Aggiungi la tua risposta
Uas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 568
