Can I glue my lifting screen back down after replacement?
So my screen had cracked, and with my warranty up, I decided to replace it myself with a digitizer I purchased off eBay for roughly $40. Replacement went fine, but now after about two days, the top portion and now sides of screen have begun to lift away from the frame, and a gap is widening between the glass and digitizer frame. Versus purchasing another digitizer assembly, or having Apple do it at an astronomical cost, I would like to just try and appy adhesive to the problem areas, and DIY it. What kind of adhesive would I use is really the only question that I would have. I figured superglue would become to brittle and eventually crumble under shock, but then hot glue does not hold well either. Ideally I need a glue that does not expand upon hardening, and maintains a strong hold between surfaces. If anyone knows of a store bought equivalent to Apple's adhesive, your knowledge would be greatly appreciated. Thank you for your time.
-Jonathan
Questa è una buona domanda?
