Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Domande Visualizza tutte
MacBook A1181 when starts the screen is dimming - no inverter
I got a used macbook A1181 2006 Core Duo 1.83 Ghz (32bit- non Estar) and there was a problem, at the begging, on the battery charging issue. I opened the macbook and I found a wrong battery connector / sleep SW component. To be clear:
My logic board supports this (Non Estar- 20pins): MacBook Battery Connector/Sleep Sensor (non-Energy Star)
I found this (18pins): MacBook Battery Connector/Sleep Sensor (Energy Star)
The problem was that, when I insert a battery (original or not) the screen was dimming while (for example) surfing on the internet. So the macbook had not battery support - only by the cable.
I supposed adding the 2 missing pins manually could solve my problem.
After of many tries of adding 2 more pins and many SMC and PRAM resets, my screen dims (like inverter's problem) when macbook starts.
The only way to open properly without dimming screen is when I reset SMC and start the macbook - and fan is go like crazy!!! (that's meaning not inverter's issue)
After that I thought to clean all contacts with isopropyl alcohol in any case.
I'm trying to find the problem that I caused and I believe that if:
1. it's a software issue: is about SMC resets etc
2. it's a hardware issue: is logic board power issue
P.S. I also give you some photos from (a) the logic board (b) battery / sleep sensor and (c) a video by laptop's behavior:
https://www.dropbox.com/sh/0spkzmkjetys4...
Thank you in advance and sorry for my English.
Immagine MacBook Battery Connector/Sleep Sensor (non-Energy Star)
Prodotto
$7.99
Immagine MacBook Battery Connector/Sleep Sensor (Energy Star)
Prodotto
$17.99
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
I made to bring the backlight on screen back!
I've got a multimeter , I also found the schematics and I was trying to calculate the contacts on the logic board nearby the Inverter.
By mistake, I brought together two contacts,t he L9400 and the neighbor of it and suddenly I got the light back on the screen!!
I do not know if this is a proper way, but I'm thinking of putting a conductive metal between them.
Check the photos !!
Let me know if it seems appropriate.
Thanks in advance
Punteggio 0
I bought a used Macbook 3.1 and I've upgraded to this. The compabilities between the two devices are less that I thought.
Punteggio 0
Aggiungi la tua risposta
tsoump sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 86
