Cannot access home-page settings
I rooted my tab and deleted some files I thought I recognised and didn't need. Now, having done a hard reset, although the tab works better in some respects, I cannot access 'settings' on the home page, so cannot, for example, link up to new WiFi provider. I really would appreciate some help!
Questa è una buona domanda?
7 Commenti
Probably need to reflash the system firmware using Samsung Kies or downloaded firmware from Sammobile.com.
da Ben
Hi Ben,
Thanks for your suggestion. I'm not sure if doing a factory reset (which I have done) is the same as 'reflashing the system firmware'. I have reconnected to Kies on my desktop, but because the tab shows latest firmware is already installed, there is no option for reloading it from Kies. if I am missing the point somewhere, please explain. If I could reformat the tab, I guess I could then do a fresh install of the firmware, but I don't see an option for that either!
da David Payne
It's not possible als far als i remember to ref lash with the kies tool. You'll need a 3rd party tool like Odin for that. Next to that you'll need the proper firmware to flash.
Unfortunately, they are region specific, so it's tough finding the right one. For this you'll need the info from the currently installed firmware.
To Check your GT-P1000 tablet’s firmware just dial this code *#1234# in the type pad or Go to>Settings>About>Firmware info.
If you need further help (or maybe the above is enough for you), can you please paste the output of this code? Then we can help picking the right firmware.
da Joost Visser
Hi Joost,
Thanks for your suggestions. I did root my tab, and although I would have expected it to have been lost after a factory reset, 'Superuser' still shows on my apps list. The installed firmware versions are: PDA:JP9 / PHONE:JPZ / CSC:KP1 (CPW). How do I get the firmware onto my PC so that it is accessible to Odin? Thanks for your guidance.
David Payne
da David Payne
Factory reset doesn't remove the rooted stuff u fortunately, it just removes a predefined set of user data, that's why a full reflashed is needed.
da Joost Visser
Mostra altri 2 commenti
