Salta al contenuto principale
The first generation Mazda MX-5, or Miata.
transmission is stuck in reverse
who do get a maual trmission out of reverse?
Questa è una buona domanda?
Punteggio 0
1 Commento
Thanks Ray for the effort!!
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi
Adjust the clutch wire..leading to the gear box
or push the clutch arm on the gearbox..while someone in the car pushes on the clutch peddle then wiggle the gear stick free!
Happy driving
Ray
Punteggio 0
1 Commento:
MY Mechanic friend found on another blog that this is a common problem for some early years; even after a recall repair. He said remove reverse light and use a small flat screw driver to move actuator....With a $50 tow and $25 repair, I guess we all may have learned a leason.
da
Aggiungi la tua risposta
RICKY WEEKS sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,924
