Salta al contenuto principale
The Toshiba Satellite L300 was a notebook designed and sold by Toshiba that came with a version of Windows Vista. They were sold around May-June 2009 and while ineligible for the free 7 upgrade, time past and upgrades are unclaimable now, run 7 home premium well without upgrades mainly because of Vista's resource hog quality. Also known as Toshiba Satellite L300-04P (PSLB8C-04P01X).
30 Domande Visualizza tutte
How to repair a USB port that won't accept a USB device?
I tried to plug in a USB cacble to my Toshiba Laptop and it would not go into the purt completely. The connection was not complete as the device I was trying to plug into the Laptop USB port would not work. I am not sure if the problem is with the Laptop or the USB connector on the device I was trying to plug in. How can I identify the correct point of failure? Would it be on the computer USB port or the usb device I am trying to plug in.
Once this is determined, how can I repair the USB connection, or does this require parts replacement?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
droyhull sounds like a mechanical issue with the port since you cannot properly insert a USB cable/device. In that case you will have to solder a replacement USB port unto the motherboard.
Punteggio 2
Aggiungi la tua risposta
droyhull sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 136
