Salta al contenuto principale
I can't download my pictures to my computer
Problems downloading images to computer.
When I connect the camera to computer via a USB cable it does not register on computer (I don't get the alert sound), hence I can't do anything.
Questa è una buona domanda?
Punteggio 2
1 Commento
What is your computer Windows or Mac?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Have you tried a new cable as well as a different USB port on the system? Is your camera able to charge via the USB connection? If not I suspect the cable is bad.
While not as easy as plugging in your camera, you can take the memory stick out of your camera and use a Sony memory stick to USB adapter which is connected to your computer.
Punteggio 1
Please check the connection of the USB-ports. Maybe your USB-output/input doesn't work correctly.
Ich hoffe,ich konnte ihnen helfen.
Punteggio 0
Aggiungi la tua risposta
ROBERT SAVAGE sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 741
