Salta al contenuto principale
Why won't my laptop turn on?
My laptop was on and then it suddenly went off.
When I press the power button it flashes 5 time but doesn't power up, the charging light doesn't come on when plugged in.
Any help on how to fix this problem would be great thank you.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Check the LED on your charger if it is flickering or if it makes any noise when "charging" as there is a possibility the charger to be damaged and not the laptop.
da
Aggiungi un commento
1 Risposta
Have you tried wiping off the battery contacts with alcohol? How about your charger /adaptor if all trhee are good then your last chance will be the battery do you remember dropping it? When a battery falls a lot of rimes will get ruined, hope i was of help
Punteggio 0
Aggiungi la tua risposta
Izzi Hotson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 173
