Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Went Under Water- Can I buy all parts?
What parts should be changed after iphone went diving with me??? lol
Only motherboard? or All internal parts are required to be changed? How to identify what to change? Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Uh... I wouldn't do those things. I would disassemble the phone, clean the connectors with 90% isopropyl alcohol, then find out which parts need to be replaced
Punteggio 1
This is the "meaning of life question" for underwater cases. You won't know if it works until you try powering it up, and if there is still water present, it could damage the phone even more. If you haven't already, you could try taking the phone apart, and leaving the components out on a ESD mat to dry out for a few days. Put it back together, and see if it works. iFixit also has a "rice bag" I believe, where you can drop the phone in, and the rice removes the moisture from the device. (Be prepared to buy a new iphone just to be safe, no matter what you choose to do.)
Punteggio 0
Aggiungi la tua risposta
Rosemeire sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 67
