Salta al contenuto principale
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
408 Domande Visualizza tutte
iPad Lock Button doesn't work
I have sort of an odd problem that I was hoping someone in the community could give me a hand with. My iPad 4th gen wifi has some odd issues with the lock button. Not only does it not work (even after replacing the lock button/volume ribbon) when the iPad was in use the assistive touch menu would not even lock the device. I was wondering if that could indicate the problem being more logic-based or if it was perhaps a fault in the board that connects the headphone jack, cameras, and lock/volume buttons to the logic board?
Any help would be great.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Id try another lock ribbon cable and see if you cant find a replacement board that the lock ribbon cable plugs into. I think they are separate. I cant remember off the top of my head, if they are or not. I had the exact same issue and it was the lock ribbon cable needed replacing.
Punteggio 0
1 Commento:
Thanks for the help, I'll give it a shot.
da
Aggiungi la tua risposta
Preston Stone sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 144
