Salta al contenuto principale
Repair guides and support for LED, LCD, HD and other Vizio TVs.
584 Domande Visualizza tutte
Vizio 48" Model E470I-A0 Black Screen
Hello I have a Vizio 48" Model E470I-A0
complete black screen. I did the flashlight test and able to see the picture in the back, but it flickers a little bit between lighter and darker spots.
Is this the LED back lights or it's the power supply.
Thank you in advance.
Questa è una buona domanda?
Punteggio 0
Commenti:
Excellent I will try that.
Thank you Gary
da
Aggiungi un commento
Batterie per PC portatili
Una soluzione semplice per un grande aumento di potenza.
Acquista ora
Acquista ora
2 Risposte
Risposta Più Utile
@randym most common error is a failure of the power to the backlight. Check to see if your TV has a separate inverter. If it does not replace the power board.
Punteggio 3
Turn all lights off in the room and with tv turned on, look through the vents on back of tv. If you can see lights it is not the LED back lights.
Punteggio 0
Aggiungi la tua risposta
Randy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,146
