Salta al contenuto principale
Modello fine 2011, A1278 / processore i5 2,4 GHz o i7 2,8 GHz
584 Domande Visualizza tutte
Can I swap the monitor between 2012 and 2011 model?
Hello I have a MacBook Pro (13-inch, Early 2011) with broken screen, everything else is working. My friend has a MacBook Pro (13-inch, Mid 2012) without logic board and hard disk, he can give me the screen. The question is: Can i put a macbook pro 2012 screen in 2011 macbook pro?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hey marcinjak9 ,
I can't find anything explicitly stating that they're compatible, but according to this Answers thread: "I'm trying to find the difference between 661-5868 and a 661-6594", someone was able to swap an early 2011 display on to a mid 2012 MBP. I imagine that it should work the other way as well, but don't quote me on that. The actual procedure of replacing the display is the same across both models, so it definitely can't hurt to try it!
Immagine MacBook Pro 13" Unibody Early 2011 Schermo
Guida
Sostituzione schermo MacBook Pro 13" Unibody inizio 2011
Difficoltà:
Difficile
1 hour
Immagine MacBook Pro 13" Unibody Mid 2012 Schermo
Guida
Sostituzione schermo MacBook Pro 13" Unibody metà 2012
Difficoltà:
Moderato
30 minutes - 1 hour
Punteggio 2
Commenti:
Yes i've noticed the same procedure of relpacing but i wanted a confirmation.
And swap logic board from 2011 to 2012? it's possible?
da
Aggiungi la tua risposta
marcinjak9 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 133
