Salta al contenuto principale
Fixes and troubleshooting for all kinds of UAV problems.
770 Domande Visualizza tutte
JJRC H26W drone won't connect to remote properly
Just got new drone. It won't connect to the remote sometimes at all and I am unsure why. If the drone does connect to the remote it will not take off and then propellers will continue to spin even if I reduce the throttle to nothing. It will then disconnect itself from the remote.
Questa è una buona domanda?
Punteggio 2
5 Commenti
I have kind of a similar problem with my h26 it wont create wifi hotspot to connect phone to it.
The drone flies fine and connects to remote ok but just cant see it as a wifi to connect phone. Any help would greatfull
da
is there anybody who can help me ..
I bought a H33 drone for my son.
but at that time I wanted to try the drone before I put it into my child, this is the chronology
that time I play myself after that there is a small child brings the exact same drone jjrc h33, then we will play together, time abis ignited both the drone fly with one remot, while remot one does not want to connect until now ,,
how to get each drone back to original keremot ,,
whereas remot does not want to connect to that drone ,,
what to do and how to be thankful
da
How to pairing a drone H36 to controller
da
Is it possible if I connect my mobile hotspot to fly drone will it work or not because you cant find network everywhere
da
having the same problem please give me the guidance Thank you
da
Aggiungi un commento
4 Risposte
Risposta Più Utile
HI, try to calibrate it. First connect drone to remote. Turn on both devices; move throtle stick up and down fast, including rigth stick - moving it 360 - . There you have the connection ready, now move both stick right-down or southeast at the same time. There you have, drone connected and calibrated.
Punteggio 1
1 Commento:
I will try this today. Thanks for your input and answer.
da
Hi guys i can help you to pairing a drone,First open a drone and open a remote control and connect to a drone and start do a calibrate a accelerator joystick and steering joystick to the left bottom corner.then release all the button till the flash of the drone indicator light turns into constant light and the calibrate complete
Sorry the is for drone H36 only.
If that can pairing to your drone i just say good luck for take off the drone
Punteggio 1
depress the lock button on transmitter BEFORE turning EITHER on then turn on trans while holding the button then turn on the drone They will both beep then you are bound and perform compass calibration..
Punteggio 1
Well, it's a $60 QuadRotor which is a red flag to me.
Have you tried removing the battery from both devices for 10 minutes, then plugging back in and attempting a resync of the devices?
Are you certain you've not damaged the remote or QuadRotor itself with water or impact damage?
Punteggio 0
3 Commenti:
I too face the same problem but my problem has arise when it had a crash landing
da
Just because it's a 60 dollar drone, it still matters to this person. I've got a jjrc 5 epic new in box will not bind. Box was not damaged I've never dropped drone or controller. Have tried everything still will not bind. Good luck to others not much I can do as China/bangood do not answer emails and no phone contact info I can find.
da
da
Aggiungi la tua risposta
Ben Coward sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 22
Tutti i Tempi: 12,195
