Salta al contenuto principale
Why does my phone wont turn on?
my phone, "Lenovo A319" wont turn on . even if I press the power on button for long period of time, it still wont turn on, what should I do? I tried charging it, the charging symbol pops out, but then its not moving... then I tried pressing the power on button, while charging,''' it just wont turn on... what should I do? please help me! the battery is low when I go to sleep, I decided to charge it at morning, then it happen it wont open....
Questa è una buona domanda?
Punteggio 14
4 Commenti
i want on my phones lenovo but so long i wait still not show
da
First remove its battery and just take it and throw it to the closet
As battery is most costly in the phone
Bcoz this phone is an utter waste of money
da
i cannot use my lenovo phone, it does not open..pls help
da
What do you mean it dose not open?
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
Ok so try to open it( at your own risk) and try to find the battery snap. Then tighten or clean the snap and click it back in. If not that try a new charger and keep it on charge. You can always call the company if it dose not work. Sorry if this is not that help full
Punteggio 1
bécaose you have dead rome and know how to fix it
1sttep :you need too dawlond sp flash tool and the rom for lenovo a 319 and just follow this man https://www.youtube.com/watch?v=grg2-bL5...
steep 2 : you need to fix imei code this his vidoe https://www.youtube.com/watch?v=rRjJgWF5...
and enjoy
Punteggio 0
4 Commenti:
my lenovo A319 is not starting after showing logo. tell me solution plz
da
I'm having the same problem
da
My lenovo phone is not even showing its logo. At first it showing the logo after that I flashed it by All format+ download now its not even get started and not showing charging symbol Also how to rectify it???
da
My lenovo A319 shows the charing symbol but when i try putting it on, it gets stuck just showing the logo...i guess this is a software problem, pls how do i fix this
da
Um you may have to switch out the battery. If the phone is old or sometimes something goes wrong the battery could die. You can try to open the phone and take the battery out and put it back in. Do it at your own risk. But before that you can try to call the company and ask for there advice. Most likely they may be able to properly fix it for you or tell you how to fix it. Best of luck to you and hopefully this helps.
Punteggio 0
Aggiungi la tua risposta
vanjosephpareja sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 28
Tutti i Tempi: 8,565
