Salta al contenuto principale
Modello A1312 / metà 2011 / Processore Core i5 da 2,7 e 3,1 GHz o Core i7 da 3,4 GHz, ID iMac12,2
708 Domande Visualizza tutte
How can you test the power supply
My iMac doesn't power up. I watched a video on how to change the power supply but how can I check to see if the power supply is or is not working properly? Could my iMac have another issue as to why it is not powering up? It seems like there isn't any power getting to the computer at all. I checked the power cord and there is power going through the actual power cord from the outlet. I also checked to make sure there was power coming through the line that connects to the power supply (the 2 prong connection). Could it be the power button itself? And can the power button be replaced?
Update (04/25/2016)
I don't see any LED lights inside my iMac. I've looked for them.
Questa è una buona domanda?
Punteggio 1
2 Commenti
What are the diagnostic LEDs telling you?
da
I have same problem too on my 27" iMac. Mine is showing only one led light on the board. please help!
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
On the 2011 model the diagnostic LEDs are located to the right of the RAM slots. On other models they are in different locations and we have to know your exact model.
Punteggio 1
1 Commento:
i think shannon was referring to the output voltage coming out of the power supply. how do we test these and what should be the voltages?
da
Aggiungi la tua risposta
SHANNON sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,397
