I would have to inspect the printer hardware to give my opinion on which part needs to be replace.
Here a step by step troubleshoot guide with great graphics of your printer.
http://www.brother-usa.com/FAQs/Solution...
Here is another troubleshooting guide.
Brother 9130, 9330, 9340 Smeared Print or Creased Paper Diagnostic Tips
1. Blurred or Smeared Print – The coating on the rollers have been falling apart on these fusing assemblies. This can lead to smeared or blurred print as the paper feeds through the fuser. Heat and pressure bond the toner to the paper in the fuser. If the outer coating is coming apart then you will have parts of the print that is not getting properly fused and will lead to blurred or smeared print.
2. Creased or wrinkled paper – Just like above, the outer coating of the rollers are coming apart. When this happens you will get creases in the paper as it gets pressed together unevenly. Also, customers will say the paper is wrinkled, indented, or embossed.
3. When I’ve seen this happen it has been pretty easy to troubleshoot. You open the back door and the fusing assembly is right there. If the coating of the rollers is coming off it is pretty easy to see as the roller coating is missing from the rollers and is found throughout the back of the machine near the fusing assembly.
Votato
Annulla
Punteggio
3
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
