Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
3401 Domande Visualizza tutte
Rear camera doesn't work even after replacement
Hi everyone
I have iPhone 5 that the rear camera doesn't work.
I have restore the phone to factory settings and replaced the rear camera and still no luck.
The camera is just black. Front camera working.
I disconnect the battery and connect it again.
Any more suggestions please help
Thanks
Risposto! View the answer Anch'io ho questo problema
Questa è una buona domanda?
Punteggio 1
Commenti:
I have the same issue with an iPhone 5s.
da
Did you try to factory reset the phone with iTunes?
da
Aggiungi un commento
Kit per Nintendo Switch
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
3 Risposte
Soluzione Prescelta
For example it's not the first time that I see this component u13 fail. If you can measure the rear camera tension on the line before this component but not after it you can remove it and run a jumper to restore the tension that allows the rear camera to work. It could also be one of the many filters or capacitors that are on the rear camera connector lines, they are a lot. It's not easy to find the problem and it's also more difficult to fix it without a microscope and some experience in microsoldering.
Punteggio 0
Commenti:
thank you very much for the support.
da
you're welcome
da
Take it to Apple ask them for a complete fresh install of iOS not just a restore
Punteggio 0
Commenti:
Any other suggestions different than taking it to Apple?
da
There are several component on the board that could have failed so there is not the right communication between the logic board and the rear camera. It is a microsoldering work, without the right equipment and skills you can't do anything more than that, I'm sorry. You could try another camera but it almost impossible that the two you have now are both faulty.
Punteggio 0
Commenti:
Hi James can you send me example of the components that may fail? Thank you
da
Aggiungi la tua risposta
Mimi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 138
