Blank screen after replacement
I've just replaced the screen on an IPad Air 2, I am testing it before final assembly and the screen is completely blank. I have plugged the iPad into iTunes and it is recognised correctly although I can't do anything with it because the device is locked and, of course, I can't use the screen.
I have tried reattaching the old screen (minus the home button), this was broken but produced a distorted image, however now it isn't producing anything visible at all.
I believe that the three connectors are in place correctly, they all gave the usual 'snap' as they went in.
I'm looking for any suggestions of what might cause this to happen. I have transferred the home button from the broken screen and obviously that is s delicate operation, could a blank screen point to a problem with the home button or should the screen fire up without one?
Any help appreciated
Questa è una buona domanda?
3 Commenti
Did you turn off the iPad and unplug the battery before disconnecting and connecting the front display assembly? (Digitizer and LCD flex cable plugs)
da Ben
No I didn't. I followed the teardown instructions which show the screen being removed with the battery still connected. I have also done iPhone battery replacements where is is not possible to disconnect the battery until the screen has been removed. I see that in the comments on the teardown page someone does recommend disconnecting the battery before the screen but I hadn't seen that.
da Gordon Maynard
I was replacing the iPad 10.5 air 3 generation I was changing the lcd and now there is no image but the iPad is on is just black but I can Hera the sound
da Sergio
