Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus.
4842 Domande Visualizza tutte
unable to focus close objects after replace camera lens
i replaced the crack lens of my iphone. but, now i am not able to focus on close objects.
Do I also need to replace the camera bracket as well.
When remove the camera bracket, it got mess up, but i try to straighten it out.
Please advice.
Thanks.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
Batterie per PC portatili
Una soluzione semplice per un grande aumento di potenza.
Acquista ora
Acquista ora
1 Risposta
Risposta Più Utile
Two things typically happen in this scenario, either the camera's shorting out and disabling itself before the camera comes in the focus leaving the app in and unfocused state; or it's not's aligned with the camera hole on the phone. It maybe constantly trying to focus on the piece of perimeter in front of it making for a permanently unfocused state.
The purpose of that transparent bracket is the hold everything in place. Even a millimeter often wreck everything.
Cameras often come with brackets when you purchase them, and the bracket alone can be as much the camera even. It might be worth getting a new camera lens bracket combination.
Punteggio 1
Aggiungi la tua risposta
ChiangFeng Li sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 79
