Why isn't the chuck able to tighten?
When i turn the head of the drill to loosen the head nothing is moving, what do i do?
Questa è una buona domanda?
The problem you are facing is because of the planet gear inside the chuck. the gear might be loose, or some the components may be broken and need to be replaced.
Follow our guide (haven't completed the guide yet) that provides a step by step process on how to do so.
Check out our Troubleshooting
for more help.
My drill had the screw that holds the chuck to the shaft come loose, and it bound up inside so the chuck wouldn't turn. I took it out, and it worked fine after that. The chuck hasn't fallen out either, must be glued on.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 44
Tutti i Tempi: 6,092
