Unable to boot the phone. Stuck after the logo.
The phone is unable to boot. It get's stuck after the Xperia symbol and doesn't function (not even switch off). The phone switches off when the battery drains. How do i fix it?
Questa è una buona domanda?
Punteggio
2
Have you tried using sony pc companion to reinstall it?
da Wadski
No. But the bootloader is not loading too when power + volume up key is pressed.
How do I fix it?
da Prithvi Shah
i would download pc companion and try that way.
da Wadski
Definitely worth a try. You will lose all your data on the device when you restore via Sony PC Companion. Make sure you get the model number correct. There is usually a white tab on the side that you can pull out of one of the card compartments that has the model number on it. Otherwise the model number may be on the back or bottom of the phone instead.
da Ben
