Water Damage: Runs on AC, Battery won't charge
My MacBook Pro got a bit wet, and now only runs with the MagSafe plugged in. With it plugged in, everything works as expected, but the battery does not charge, and my power source is listed as the power adapter. I have tried replacing the DC-In board for a chance at an inexpensive fix, but the new board shows the same symptoms. I have a feeling it's related to the battery connector to the logic board, as I'm seeing some very slight corrosion on the contacts of the board and can't seem to remove it after trying to clean it with isopropyl and a toothbrush. Below is the Power System Report and the Apple Store Diagnostic indicated a 'Failure' for the battery. I'm debating on replacing the battery or using a Logic Board Damage repair service if this can't be fixed easily. What should I do? Thanks.
Battery Information:
- Model Information:
- Serial Number: D865253W2ZTFY5HA7
- Manufacturer: SMP
- Device Name: bq20z451
- Pack Lot Code: 0
- PCB Lot Code: 0
- Firmware Version: 702
- Hardware Revision: 1
- Cell Revision: 3217
- Charge Information:
- Charge Remaining (mAh): 4725
- Fully Charged: No
- Charging: No
- Full Charge Capacity (mAh): 6183
Health Information:
- Cycle Count: 71
- Condition: Normal
- Battery Installed: Yes
- Amperage (mA): 0
- Voltage (mV): 12235
System Power Settings:
- AC Power:
- System Sleep Timer (Minutes): 1
- Disk Sleep Timer (Minutes): 10
- Display Sleep Timer (Minutes): 10
- Wake on AC Change: No
- Wake on Clamshell Open: Yes
- Wake on LAN: Yes
- AutoPowerOff Delay: 14400
- AutoPowerOff Enabled: 1
- Current Power Source: Yes
- DarkWakeBackgroundTasks: 1
- Display Sleep Uses Dim: Yes
- GPUSwitch: 2
- Hibernate Mode: 3
- PrioritizeNetworkReachabilityOverSleep: 0
- Standby Delay: 10800
- Standby Enabled: 1
- Battery Power:
- Display Sleep Timer (Minutes): 2
- DarkWakeBackgroundTasks: 0
- GPUSwitch: 2
- Hibernate Mode: 3
- Reduce Brightness: Yes
Hardware Configuration:
- UPS Installed: No
AC Charger Information:
- Connected: Yes
- ID: 0x0921
- Wattage (W): 60
- Family: 0x0085
- Serial Number: 0x00b93512
- Charging: No
Questa è una buona domanda?
