iPhone 5 Audio problem
Hello
I have received an iPhone 5 (ios 9.2.1) that could not power on and was not able to charge the battery when is connected through lightning connector... just showed a black screen.
I removed the battery and reading with a multimeter, the battery showed 0v. I managed to revive the battery using this method https://www.youtube.com/watch?v=nxCUkHjY... after that, the red charging icon appeared and after about 2 hours the battery was fully charged.
Everything seems to be working fine except...
- When an incoming call is received I can hear the ringtone, but at the time to answer the call I can not hear anything and they can not hear me.
- When I connect headphones to listen music, the sound keeps coming out from the iPhone speaker, not from headphones.
- When I run the voice memos app, the record button is disabled and I cannot record. (voicememo screenshot)
I've reset to factory settings and also restored the ios 9.2.1 firmware via itunes but the problem persists.
Have you got any idea to solve the problem?
Thanks!
Questa è una buona domanda?
2 Commenti
Hi,
I had my charging port replaced as my iph 8 wasn’t charging. After it’s been renewed I’ve noticed that when I make outgoing calls I can hear the person I’m calling but they can’t hear me. I plugged my headphones in and they can hear me fine through headphones. I recorded a WhatsApp voice clip and when I and the person I’ve sent it to listen to it, it’s just static. This fault only occurred after the charging port renewal. Can you please give me advice ? Thanks
da Dianne
@dianne_ ,
How long ago was the repair done?
If not that long ago, take it back to the repairer and show them the problem.
Most reputable repairers give a guarantee on their work even if it is only ~30 days.
da jayeff
