Salta al contenuto principale
The drone is a Wi-Fi capable and it's equipped with a built-in HD camera. It is used for taking pictures and filming. Model number: PF722000
35 Domande Visualizza tutte
rapid power loss power dives from 100% to 3% in seconds
the power reading reduces from 100% to " critical battery power" in about 10 seconds after take off any advice . tried two new batteries same result. Charger charges back up to green within 15 mins. switch off copter and reboot shows the power at a level you would expect (80-90%) than does the same again when you you press take off. any advice ANYONE cheers
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Try a different charger and measure the battery voltage if you have a multimeter.
Punteggio 0
Aggiungi la tua risposta
colin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 100
