Salta al contenuto principale
Rilasciata in Italia nel dicembre 2006, la Wii è stata la prima console domestica di Nintendo a supportare direttamente la connettività Internet, supportando giochi online e la distribuzione digitale di giochi e applicazioni multimediali tramite il Canale Wii Shop.
How do you fix a button that won't press?
The Wii took a tumble a while back, and since then, the eject button doesn't click anymore. Unless its positioned just right, it'll forever try to eject. How do you fix/replace an eject button?
Questa è una buona domanda?
Punteggio 8
Aggiungi un commento
6 Risposte
Risposta Più Utile
If I'm hearing you right, the console is constantly trying to eject the disc while the button is not being pressed. A solution you may want to consider is removing the button entirely (I'm pretty sure you can still eject the disc from the Wii menu). Try removing the faceplate to get to the button and remove it, to see if that fixes the problem or at the very least to clean out any broken plastic components that may still be in there. Wii Faceplate
Here's the part: Nintendo Wii Faceplate
EDIT: Whoops! Turns out you can't eject the disc from the Wii Menu. I tried through a whole episode of Seinfeld.
Immagine Replace the faceplate and its buttons.
Prodotto
$19.99
Punteggio 5
iFixit now has the part you need to repair your Wii (instructions linked to in BWest's answer)
Prodotto
$19.99
Punteggio 3
the eject button can be replaced but its very small. I use a digital microscope to clearly see the solder points.
Punteggio 1
clean the buttons some times got dust around
Punteggio 0
Yes and i need you to fix it
Punteggio 0
I took apart the Wii and found the disc holder and pushed the egect button a couple times then put it back together and the your set
Punteggio 0
Aggiungi la tua risposta
Kevin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 37
Tutti i Tempi: 19,823
