Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
New LCD's only show backlight on, No pictures
iPhone 6 needs a screen replacement. When the new screen is installed it took several boots to get a display. After getting a display, i come back to the phone about 2 minutes later and i just get backlight. Tried rebooting, still only backlight. tried again, got LCD picture. The same process has to be repeated to get any kind of picture on the screen, But then shortly you only get backlight again.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
did you try another screen?
maybe it's a bad screen.
Punteggio 0
I've faced this issue now twice with iOS 9.3.2. After screen replacement phone boots but switches off after about 2 seconds. Same happens if i try it again. Have tried to plug out the battery connector but it seems not to help.
I've found out that only thing that helps is complete restore on iTunes.
Whats happening with iPhones?
Punteggio 0
Aggiungi la tua risposta
Mark VanderPol sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 750
