Salta al contenuto principale
Released in March of 2014, can be identified by the model number KX-TGE233 on the bottom of the main docking station.
Why can't I make calls?
The device is powered on and appears to be functioning, but when I try to make a call, it doesn't go through.
Questa è una buona domanda?
Punteggio 4
1 Commento
my phone is model kx-tg6591
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
In its operation instruction, the one of problems is stated as:
"This product is unable to make calls when:
– the handset batteries need recharging or have failed.
– there is a power failure."
Since the problem is not about the power, it may follow this condition:
"If you cannot make calls, change this setting
according to your telephone line service. The
default setting is “Tone”.
“Tone”: For tone dial service.
“Pulse”: For rotary/pulse dial service.
1 [MENU]#120
2 Select the desired setting.
3 [SAVE] and [OFF]"
Punteggio 1
1 Commento:
i can't access menu. when i press menu *120 won't go through
da
Aggiungi la tua risposta
Nico Cruz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,379
