Water in door not working, leaks inside refrigerator.
First, the ice maker works fine. When I try to get water from the door, no water comes out, but I can hear water running inside the refrigerator. Water settles in the bottom of the refrigerator side. It sounds like the water is spraying about mid-way up the back of the refrigerator side behind the panel and running down. I assume there is a broken line or loose connection there. What is the routing of the water-to-door water line? I had assumed that the line ran from the dual valve at the rear bottom of the unit under the fridge to the lower freezer hinge. Is there another line that flows when water-in-the door is requested?
This refrigerator is in a VERY tight location and will have to be pulled out and then moved sideways to access the back of the unit.( Pulled out, I have 3 inches to vacuum the back)
Questa è una buona domanda?
