Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
First step to repairing home button
My iPhone 6 Plus was dropped into a jacuzzi about a week ago now, and I've since moved over to one of my old phones. Having no pentalobe screwdriver to get the phone open, I got as much water as I could out of the device, and left it to dry hoping for the best, I know I could have done more...
Turning the phone on now, everything seems to be working except the home button. I went into settings and can turn AssistiveTouch on, but I'd really like to have my home button working again instead.
Should my first step be to just obtain a pentalobe screwdriver, disconnect the home button and see if I can repair the water damage when found? Or should I just order a new home button and proceed with the replacement? Or is there another solution to maybe fixing this? At the moment like I said, everything is working fine minus the home button. About a day or two after the accident the screen would continuously freak out as if I were double tapping the home button to bring up the app switching, but now all seems fine minus the home button
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
DO NOT REPLACE THE HOME BUTTON.
Clean the board and try to remove as much water damage as possible. If the Touch ID is broken, go to Apple.
Punteggio 1
2 Commenti:
I wouldn't mind if the Touch ID is broken to be honest, mainly just getting a functioning home button again. What would taking the phone to Apple accomplish? I believe they don't cover water damage on their limited warranty, correct?
da
Yes, but if you touch anything in iOS, it will brick forever, because Touch ID is dead.
da
Aggiungi la tua risposta
Ryan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 87
