Macintosh 512k won't boot up, displays error code "01C3BD"
I've been working on restoring a Macintosh 512k for the past month. Previously the computer had some pretty rough water damage, but when I began working on it, the computer ran just fine aside from some mechanical errors which i've since corrected.
This weekend I was planning on replacing a ROM chip which I'd broken one of the prongs off of by accident, but the computer has other plans in mind, as it turns out.
I flipped it on a couple minutes ago, and at first it was booting up like it usually does. It recognized the disk I gave it (System 3.2), and moved onto the "Welcome to Macintosh" screen. However, before the text could even appear in the box, the whole system cut, and the Mac was sad facing me. Yikes.
I've tried rebooting and it won't even try to boot properly anymore. It will only give me the sad face with the code "01C3BD" below it.
Any idea how I can even begin to fix this issue?
Questa è una buona domanda?
3 Commenti
UPDATE: I've deduced that "01" means ROM error which is pretty ironic since I was just about to replace it. The other four characters are not listed in my handling book, but I'm sure that this could perhaps just be solved with a ROM replacement.
da Brooke
Is there a - sign on the error code?
da mayer
there is no hyphen in the actual code itself, but there are lines moving around below the code.
da Brooke
