All the electric windows
all electric windows not working properly. They go down a couple of inches and do not go back up. Is there a relay problem ?
Questa è una buona domanda?
tomd12983 , Most common issue for power windows not wanting to go up and down easily is the rubber channel/gasket they travel in needs lubricated. You may need to give them a helping hand initially to go up and down until lube works in. Get a can of silicone spray lube(the one that can take the straw on the nozzle), with the windows down liberally spray the lower channels and then run the windows up and down until moving freely. If this does not fix your issue or fixes some windows, the issue could be failing/dirty contacts on switch or power window motor lazy/faulty. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 233
1 Commento
This problem is indicative of the driver controll side switch.
Ease the pain of repair by buying a new switch on eBay , which are usually economical to buy...
da Bill
