How to repair/replace low voltage lead
We've all seen it happen.
The silicone rubber insulation on the cable connecting the brick to the laptop has been nicked and now the damage is 'running' exposing the shielding wires.
Apple's response is replace it - Yeah at $100+ per time and I'm sick of it. I wanna Fixit.
I have tried wrapping it with insulating tape but have not had a lot of success because the silicone shrinks and displaces the tape.
I found a good link to doing the job but the embedded link for the part was broken and I have not been able to find a new source.
Has any body got a new source of parts?
Risposto! View the answer Anch'io ho questo problema
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
Sfoglia il Nostro Negozio
1 Risposta
Soluzione Prescelta
$100 ? Do get a kiss with that or do they just...........
Here's a guide and you can get replacement cables on eBay pretty cheap:
How to Repair a MagSafe Connector
Apple MagSafe 1 Charger Repair
Here are several options for replacement, you did't tell which one you had:
Apple MagSafe 1 AC Adapter
http://www.ebay.com/itm/Power-Cord-Plug-...
Do a search for Mag-Safe replacement cable for your correct end.
Immagine Apple MagSafe 1 AC Adapter
Prodotto
$64,99
Punteggio 3
Commenti:
Actually it's more like A$130 and no kiss!
It's any of them. My wife's laptop uses the L type and I just had one fail on the 45W MagSafe 2 on my 2013 Mac Air. That's a work machine so my employer paid for the replacement - bonus!
I've successfully used Dave Fixedit's version.
Thanks for the eBay link
da
Here's an adapter I use all the time for switching between older and newer machines: http://eshop.macsales.com/item/Apple/MD5...
da
The parts for the MagSafe2 arrived today. I've got a few spare bricks lying around with no usable cables. I intend to try putting a type 2 cable onto an old 60W brick.
I cannot see why this should not work. Any comments?
da
Aggiungi la tua risposta
Jeff Armstrong sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 157
