Salta al contenuto principale
HP ProBook 4320t manufactured in May of 2010.
6 Domande Visualizza tutte
Can't remove CPU heatsink because two of the screw heads are damaged
I replaced the thermal paste on the CPU and Radeon chip in a 4320s a couple years ago due to over heating causing shutdown on boot which fixed the issue.
It's happening again but this time I can't remove the heat sink because two of the screws holding it in place are damaged and won't turn no matter what screwdriver I try. The driver just spins in the head of the screw.
Any advice would be greatly appreciated.
Thanks in advance!
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Have you tried these:http://www.amazon.com/Alden-8440P-Grabit...
Or use a round disc bit to carefully grind a line in the screw with a dremel so the screwdriver will grip?
Punteggio 0
Aggiungi la tua risposta
Zayn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 6
Tutti i Tempi: 544
