Fix cracked wii remote front
I cracked the wii remote front infrared panel while bowling, now it doesn't point. Can this be fixed? All other functions are still working.
Questa è una buona domanda?
The tri-wing needed to open your remote is also available in iFixit's driver kits.
[prodotto collegato mancante o disabilitato: IF145-022]
[prodotto collegato mancante o disabilitato: IF145-028]
You can try just unscrewing the case and removing the front cover and see if that helps. The front cover is just a filter that only passes infrared light (and keeps dust out). But if you damaged the sensor inside, then you'll need a new Wii remote. To unscrew the case, I believe you need a tri-wing screwdriver, which you can get at Ebay. If the sensor is damaged, you can sell the remote to a hacker who only needs it for the accelerometer.
This is what I did to my remote and it works perfect http://howtofixstuff.blogspot.ca/2013/08...
The front of the wii remote had a cracked screen because my older sister or brother and me were playing just dance 1 2 3 or 4 she or he kept on hiting it out of my hand. XD is that your problem.
Follow a guide for your wii remote, but before that, make sure you buy a replacement case/screen.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 6,500
