Why does my insignia flex 7 NOT charging?
i inserted my charger into the port, but it won't charge my tablet. I may have inserted the charger the wrong way, so it damaged the port. How do I replace it.
Questa è una buona domanda?
sometimes if you do not use the original charger and cord then the device will not get enough amperage to charge. i have had this happen with many tablets. also sometimes it can be the charger part is messed up or lose and finally the battery could just be messed up. try a differ charger to see if that works and if you can try to replace the battery and see if that makes a difference. i hope this helps and good luck on your issue
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,286
