Salta al contenuto principale
The Canon Powershot A1000 IS features a lens with 4X optical zoom and a focal length of 6.2mm to 24.8mm and maximum f-stops of f/2.7 and f/5.6.
6 Domande Visualizza tutte
Domanda Chiusa
Can't close battery cover, because of small plastic broke
So this little plastic hole just broke, don't know how to repair that. It's annoying, because for this time I'm using ducktape, but it's not practical, when you need to pull of sd card.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Are you referring to the clasp that holds the battery cover down?
da
Aggiungi un commento
2 Risposte
Hi. Probaly u will need to replace entire housing of camera.
Punteggio 0
Do you have the little plastic hole with you? If you do then super glue it back on.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 174
