Salta al contenuto principale
Modello inizio 2011, A1278 / processore i5 2,3 GHz o i7 2,7 GHz
782 Domande Visualizza tutte
Domanda Chiusa
logic board getting very hot. idling at 90'c.
I was given a mac book pro 1278 early 2011 with an i5 processor.
Unfortunately it runs very hot ( around 90'c) whilst idling. I've checked and the fan is free of dust and spinning without a problem. I've also isolated the heat source to be eminating from the logic board as every other component is perfectly cool.
I took it to the mac store and they said it may be the hard drive as it was about to fail.
Yet this makes no sense? Firstly I replaced the hard drive with a brand new one as the 320 was too small and I can't see how a faulty hard drive can make the logic board overheat?
I will attempt to replace the heat paste. But will that make much of a difference?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I have a customer with the exact same machine. I have replaced the hard drive, also it has burned up the HD/IR cable twice. It continues to run hot. I have recommended sending it in to Apple for a "Flat Rate Repair". Cost in Texas with tax and shipping is $357.00. If that does not fix the issue it then goes back to Apple under the repair warranty until they do fix it. I believe it will take a logic board replacement and is a factory defect. If there is ever a class action law suit on this one, Apple will be required to refund the repair costs.
Punteggio 2
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,139
