Salta al contenuto principale
Repair manuals and information for the Microsoft Surface book line of laptops.
207 Domande Visualizza tutte
I can't turn my surface book on
I used the surface book one evening and put it to sleep with the power adapter connected. The next morning I was unable to turn it back on again.
The detach button on the keyboard is constantly lit red and I can't detach the tablet from the keyboard.
I tried the one button and two button methods described by Microsoft to reset the device without success.
The device appears dead if it was not for the red detach light.
Is there another way to hard reset the device or to make it reboot?
Questa è una buona domanda?
Punteggio 34
6 Commenti
Thanks for your help guys, I got it to work again. see my reply to
Willis
da
Yes it worked thank you Solom
da
Yes, that worked, Awesome guys!
power+volume + and hold it really really long
turns on, boots to uefi, select exit and reboot
da
Yes, it worked, thanks so much!
da
How much long you have pressed both the buttons
da
Mostra 1 altro commento
Aggiungi un commento
16 Risposte
Soluzione Prescelta
had the same issue
I undocket it the normal way
tried all options
what worked was power+volume + and hold it really really long
fixed
Punteggio 16
13 Commenti:
My keyboard would flash and nothing else would happen. I thought my Laptop was dead.
Tried the above and It fixed it.
Whew. Thanks Solom.
da
Thanks Solom, worked just the way you described it.
da
Thanks so much Solom, it did work while everything else Microsoft proposed didn’t... you rock!
da
How long to hold down? I didn’t for just about 2 mins and nothing
da
Created an account just to say thank you. Legend
da
Mostra altri 8 commenti
There are buttons on either side of the surface (4 holes up from the keyboard) that if you press in with a paper clip and it will release the keyboard.
Then just charge the tablet and you should be good to go.
I spent hours on Microsoft's customer service hotline and they wanted to replace the tablet. They definitely did a poor job of documenting this feature!
Make sure you check for firmware updates and dirver updates, these may prevent this happening in the future....
Punteggio 3
4 Commenti:
@Aaron. Thank you for that. Saved me a huge headache. It's six holes up by the way. I had no idea you could force detach the keyboard. I was not about to wait 8 days for the battery to die.
da
Hi Aaron, what do you mean by "charge the tablet"? is there a way to charge the tablet without being attached to the keyboard? Sorry for posting this. I know this thread is very old, but I live in Brazil, no Microsoft here and my surface book is having this problem now...don't know what to do any more. Thanks Pal.
da
eferreira2705 conseguiu resolver seu problema com o SB no Brasil? Estou com o mesmo problema
da
I had the same problem. I used a video https://www.youtube.com/watch?v=4fVGQPQ3... to see how to detach using a paper clip in the hole 6 holes up on the side of the clipboard. Took some tries to get it to detach one side (each side has its own release). In my case, the power on the clipboard wasn't all the way drained. So while it was detached on one side, I pushed the power button to turn it on. Once on, I slid it back onto the keyboard and it recognized it as attached and started charging and detaching/attaching normally again. I haven't had a problem for the last few days after doing this, and it saved me the hassle of getting it repaired.
Punteggio 2
2 Commenti:
Thanks for the suggestion. Microsoft sucks. Tried all their options. Just out of 1 year warranty so was worried. :-( initially i was trying the volume and power button in docked condition. You need to hold for really long. Then firmware settings window comes up. But make sure you undock first. Then did exit from the firmqare and boot. It worked. All content are safe. People may be worried b4 doing. Thanks a lot guys.
da
That totally worked and saved my Surface Book. For me, it was the 6th hole up and had to extend the paper clip roughly 45 degrees up and needed to do both sides. Thank you!
da
I have the same exact issue.
I tried the manual detach using the two holes in the Clipboard and I managed to detach the Clipboard and then charge it.
Now, it is charged; however, this is not sufficient to restore the problem.
I connect the Keyboard again, the PC does not recognise the Keyboard, and the Red Light comes back on to be turned constantly.
Tried to clean the connectors, still didn't work.
Tried the BIOS, restart, still nothing solved.
Tried to recovery, and restore the PC, same, did not work.
I disconnected manually the Keyboard and connected it several times, and still doesn't work.
The USB in the keyboard does not charge another device...
Is the 8 days waiting the solution ? i.e. completely drain the second battery before connecting them and charge again... ?
Punteggio 1
1 Commento:
Any Update? I am in the same kind of situation right now. Warranty is also expired and MS ppl are asking for around 500 USD replacement.
da
Tried most all of the above and nothing worked. Took it to MS for repair they wanted $600 for a new base. Decided wasn't going to throw good money away again after being burned once…tablet was only two years old. Stashed the tablet and forgot about it. A couple months later decided to recharge the batteries and see what would happen. To my surprise everything worked! I clicked the display back on the base and it's been running fine ever since. I did read and tried one of the solutions that stated to let the batteries drain completely for a couple weeks and try it but that didn't work for me…guess I didn't let the batteries drain completely. Hope this helps someone…good luck!
Punteggio 1
i had the same issue and i get crazy.
only thing how i got fix it:
lift the display on the one side and push it hard back. after i tried this on both sites a couple of times, than it recognized the display
Punteggio 1
The only way to hard reset the device is if its on, i will link you to a website on how to hard reset it.
http://www.hardreset.info/devices/micros...
Punteggio 0
3 Commenti:
Thanks but the screen is off as if the device is turned off.
da
Oh.
Maybe bring it in to a Microsoft store or your local gadget store and ask them about it.
da
Thanks Zach,
That's what I wanted to do, but....
I bought the surface book in the states and brought it back to the UK where it's not on sale until the 18th of February 2016 and hence not supported.
This is bad customer support not even taking into consideration the high price Microsoft charge for this device.
I'ts fixed now , see my reply to Willis.
da
I had this problem. I took my Surface Book back to Microsoft Store and they had to replace my Surface Book.
Punteggio 0
5 Commenti:
Thanks for your reply Willis,
I'm writing this comment on my surface book after I got it to work again.
I left the device for 8 days (not connected to the charger) until the batteries completely ran flat and the red light on the detach key switched itself off. I gave it another day to make sure that the batteries were fully discharged. I then connected the charger and pressed the power button to turn it on. It booted normally after installing a windows update.
This supports my theory that the problem was not hardware related, but most probably a bug in the sleep function or power management application.
I now do 2 things to prevent this from reoccurring :
1 After use, I always switch off and I stopped using the sleep option.
2 I store the device with the keyboard detached, to shorten the time for it to discharge completely in cast this happens again.
Hopefully Microsoft will fix this bug.
da
Now going to try this myself, off on holiday in 3 days so not good timing for a return to MS, hopefully Surfacebook will be flat when I return next week :(
da
Yes, same problem here. I just wanna know whether there is no reaction or not when any USB device plugged in your surface book
da
Thanks. I got it to work again. I left it for 8 days and then booted it up and it works.
da
Am facing the same problem so you tell me to let the keyboard 8 days without touching it , what about the tablet?
da
I had the exact same symptoms: tablet thinks its disconnected from keyboard while being stuck attached and the red light staying on all the time. No 'usual' rebooting, bios fixes helped.
In my case it got stuck when I attached the tablet to base while in sleep.
While it got stuck, it did not actually lock in properly, so after some panicky hours I noticed that clipboard would actually lift a bit under serious force. So after trying every single troubleshooting guide/post I could find, I just took a deep breath, closed my eyes and ripped it off!
I noticed there was a smudge on contacts and when I cleaned it off, it started working again.
But again, in my case it wasn't properly locked in so just removing it by force worked.
Punteggio 0
3 Commenti:
da
I'm having a similar problem. When I try to turn on the keyboard flashes once but then goes off. Then nothing. Tried all of the recommended processes but nothing works. Screen detaches ok and both the red & green lights work. Stumped and really frustrated as I'm due overseas soon.
da
I had the same issue (clipboard wouldn't recognize keyboard), and there was a constant red light on the eject button. Also, Battery one (keyboard base), was not detected. Though this is not documented by Microsoft, this is a total and complete hardware failure of the dock base (keyboard). Since they are paired by serial number (and various other identifiers), you can't just swap it out. You have to get the whole thing replaced. I had the Intel Core i7 1TBB SSD 16 GB RAM with Nvidia Graphics (total beast of a machine) for less than 2 weeks. I used it for work only, and treated it with the utmostcare. Microsoft says they have to swap out the whole machine due to a failure in the dock. There are way too many bugs/glitches in the Surface Book. Extremely disappointed and would like a new one NOW, but since they are backordered, I have to wait weeks, I couldn't conscionably recommend anyone to buy this machine until these hardware failures and software glitches are fixed. My two cents.
Update (12/15/2016)
This is a complete hardware failure located in the base. Believe it or not, you can take the tablet/clipboard off with a little force st the right angle. It if it's red constantly, that won't help. It is totally done my friend.
Punteggio 0
6 Commenti:
For those having the same issue, NO! USB does not work at all. Again, hardware failure in base. At least with my issue, which will inevitably be your issue if you keep using this laptop hybrid.
da
Lastly, I have tried every alleged fix on the internet, nothing is working at a!
da
Same Issue. It's out of warranty now and they are asking 500$ for the replacement.
da
If the red light is on constantly and then as you say the base is totally totally done, is the hard drive still ok?
da
*****lift the screen part up a little press down hard.*****
*****hold the power button done for a little until it powers off.*****
>Mine was stuck with the eject button on red after I accidentally forced the tablet on turned it on then shut the screen down. Tried to yank it out. Wouldnt Budged. Unplugged usb for wireless mouse kept tryin to hard reset with charger in.
>>>>Just life screen a little push down hold power button for a little bit and it will power down. Then power on or hard reset and follow prompts.
>>>>Wahbam.
da
I have the same issue, I have tried all the above but red light still stays on , let it drain for 12 days also it's doing my nut in!
Punteggio 0
1 Commento:
Yes, I did that for 4 days and let the battery drain out, as a last resort. Luckily it's working now.
da
Before i accidently found this solution i might think i would need change new notebook..
So i am not sure if this method can work for others just sharing my experience.
I just did press power botton and at the same time press vloume buttom hold for a seconds or even longer..
(Power+volume bottom together)
Cheers bom
Punteggio 0
I had the same issue and managed to solve it by applying pressure at the back of the tablet towards the keyboard with the screen at ~45 degrees
Punteggio 0
>>>>Wahbam.
Punteggio 0
1 Commento:
Ohmigod! It worked! Thank you @solom. I'm literally sitting in the mall garage, about to go to the Microsoft store and figured I'd try this fix before I go in…just in case it worked. And it did. So, glad my Book is working again. Had to hold the power and volume button up a really long time, but it came on just like you said. uefi screen, then exit. Yay!
da
I have the same problem as well, tablet blackout with detach button red light on, and the tablet is not able to charge even I detached it from the keyboard.
Right now I am using a tape with a memo to stick down the power and + volume button as I don’t know how long it takes to get to the UEFI menu come out. I’ll just wait till I see it or wait another week to let the battery flat out.
To detach the tablet, 6th ventilation hole from both side and insert in adjacent angle for about 1 inch then you’ll hit the click to detach. Tricky part is to hold one side detach while fixing the other side, which makes it very easy to attach again…
Punteggio 0
Had the same problem as well. What worked for me two times now was to let the battery completely drain and then recharge it via the USB C port.
Punteggio 0
Aggiungi la tua risposta
Leo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 87
Ultimi 30 Giorni: 300
Tutti i Tempi: 89,738
