Salta al contenuto principale
4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
83 Domande Visualizza tutte
PSP not charging. Charge light flashes Orange.
I cannot charge my PSP 2000. The charge light flashes orange when I plug it into my charger. Can anyone help?
Questa è una buona domanda?
Punteggio 5
Aggiungi un commento
10 Risposte
Risposta Più Utile
well try taking it someone like a psp clinic ant try giving them 10 dollars or so to fix it ! keon
Punteggio 1
Just suck a dick for 5 callers and ho fix it
Punteggio 1
2 Commenti:
I’s u fucken retarded souds like you got a lot of experience sucking dick to solve your problems
da
Lmfao 🤣 😂 😂
da
Probably it's a charger problem. Try with another one
Punteggio 0
Your Psp is bricked. Reflash with pandora and install cfw. Happen many times to me. Also try going into recovery mode. Forgot how to do that but google it
Punteggio 0
It happened to my psp 3001 today , when i turn it off light orange light still turns on and it blinks when i charge it, i think the psp had a bug in the system making it think that its still charging from a/c
I fixed it by pluging it to the pc since it also charges when connected to pc, since the psp "focused on the usb charge on pc instead of the a/c charge system error" and there you go its back to normal.
Punteggio 0
it might be a charger problem
but try and take out the battery then plug your charger to the psp and try to turn it on
if it does then it a battery problem
Punteggio 0
1 Commento:
mine's dping it too. it's plugged in now but it's not charging. it turns on when plugged in and battery is not in it.
da
it happened to my psp 2000 today, when i turn it on the light turns into yellow something but when i turned it off i becomes orange
the light becomes black when i charged my psp again and i turned it off and turned it on and whallahh
Punteggio 0
the psp battery acid is out just get a new battery
Punteggio 0
It might be a problem with the LCD of the system. Try replacing it
Punteggio 0
Get a new battery it’s probably broken or ran out
Punteggio 0
Aggiungi la tua risposta
Lewis Waddington sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 131
Tutti i Tempi: 50,621
