Salta al contenuto principale
La Jeep Cherokee (XJ) è un SUV compatto prodotto e commercializzato da Jeep dal 1997 al 2001. Pur condividendo il nome del modello originale full-size SJ, ma senza un tradizionale telaio separato, la XJ presentava invece un design unibody leggero.
some general problems 1999 jeep cherokee sport
hi everyone ive had a problem with my jee here it is it staled on the freeway the other night long story short got it started like 1 hour later then staled like 20 minutes later we replaced the coil and now its running ok but after replacing the coil all my gauges are wacky sometimes one or two is on but mostly they are all off also very slow pick up so i manualy drop it down to first then second ect seems to work fine if any one has any ideas please holler at me thanks Tim
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Sounds like you are have some kind of a heat problem. Go through the engine harness and look for damaged parts of the harness. Heat long term will make wires brittle and corroded. Short term heat creates resistance in electrical components.
Punteggio 0
Aggiungi la tua risposta
tim buchan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 7
Tutti i Tempi: 637
