Salta al contenuto principale
Repair and disassembly guides for Asus tablets.
428 Domande Visualizza tutte
Won't power up or show battery icon when charger is connected
Am trying to power up an Asus Memo Pad ( ME181CX) but it won't come on using the charger.tryed the charger on another device charger works fine.some am saying the board has a problem cause the charger port on the board looks loose.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
My tab stopped charging after only being 3 months old. Had to exchange it where I bought it.
Punteggio 0
This is the third time my tab has done this. Try plugging it in to charge and leave it for 10 min take it off charger and push power and volume at same time for 10 sec the computer guy said I would only need to do that once but I had to do it 3 times and put it back on chargerit should turn on within 5min. If it don't repeat this a couple times it took 3 try for mine the first time it happened ,the second time only once. I'm back here looking for answers again this is the third time. I'm about ready to give up on this tab. I hope it works for you.
Punteggio 0
Aggiungi la tua risposta
neil xavier sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 78
