Salta al contenuto principale
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
375 Domande Visualizza tutte
What are the possible causes of an overheating CPU and MCP
Hello
After connecting a defective LCD cable on two macbooks A1304 I had no image and the CPU overheats enormously
This cable has probably short circuited a few items ...
After observing the two motherboards I noticed a transistor HS on both the Q9807 serving fueled the backlight
So I replaced these two cards but the problem is always the same :
-No Screen image
-No Startup chime
-The CPU and MCP overheating enormously
As I am not an expert in this field I prefer requested
What are the possible causes of an overheating CPU and MCP after a short circuit ????
thank you in advance for your assistance
Mother board model : 820-2375
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hello,
Tried to make the SMC reset.
https://support.apple.com/en-us/HT201295
Punteggio 1
Did you check you fan speeds? Maybe that it destroyed the fan controller on the motherboard
Punteggio 0
Aggiungi la tua risposta
David G sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 121
