charger port missing prongs- needs replaced
Prongs are missing in the charger spot. Is there a way to fix it?
Questa è una buona domanda?
Thanks for your question.
Sorry for your troubles.
Yes you can fix the port however it will require ordering the correct repacement port AND knowledge on how to solder the new component onto the circuit board.
If you are going to do this yourself than might I suggeste that you order at least two replacement parts. Just incase one of them is defective.
Hope this helps.
Good luck.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 85
