Salta al contenuto principale
The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
117 Domande Visualizza tutte
How do you replace the charging port?
How do I replace the charging port?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi,
Here is a link, which shows how to replace the battery in your model Tab. Using it shows you how to access the charge port assembly. At 3:30 minutes in, it shows the flex cable, which is part of the charge port assembly. It is directly under the person's ring finger. At 3:32 minutes you can actually see the complete assembly. You will have to work out how to remove / reinstall the assembly from the unit. Take your time and be gentle with how you go about it.
https://www.youtube.com/watch?v=yb2zQIDK...
Here is a link which shows the charge port assembly. It is not a recommendation either way to use the seller. It is only here to show you what it looks like.
http://www.etradesupply.com/samsung-gala...
Punteggio 4
Aggiungi la tua risposta
wswindell sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 695
