Salta al contenuto principale
Il Sony Xperia Z3 Compact è stato lanciato nel settembre 2014.
82 Domande Visualizza tutte
Domanda Chiusa
My Primary call mic is not working
Hi,
The Mic on my z3c is not working. I did a factory restore, even did the diagnostic and no cookie.
I disabled ok google and all that jazz. The phone is under warranty but the service center guys are refusing to consider it as the back panel is damaged and plan on charging me for the back panel and mic replacement which is completely unfair as the two had nothing to do with each other.
What do I do?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
You need to solder a new mic on the mainboard.
Punteggio 0
Did you ever try to open the back panel by yourself? If yes, they would consider that you have broken the phone and made the phone warranty void. Since the mic is soldering on the motherboard, and it is hard to replace by DIY repair work, it is better to ask for the professional for help.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 747
