Salta al contenuto principale
DIY guides for many household repairs, ranging from furniture to plumbing solutions.
4486 Domande Visualizza tutte
How to fix peeled laminate counter top?
My laminate counter has warped and peeled, creating a bubble on one edge. Is there a way to fix this? Do I need to remove the entire counter top?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Use a tech knife: Precision Utility Knife
Slit the bubble down the middle. Glue one half of it down. Then push the other side down and trim it to fit the glued down piece. Glue it into position. Use tile grout to fill and seal the split.
Immagine Precision Utility Knife
Prodotto
Punteggio 1
You could try sanding the surfaces of the laminate and substrate where it has peeled, and use waterproof adhesive to stick it back again.
Punteggio 0
Commenti:
I think this requires a bit more than just sticking it back down. It has warped and won't lay flat when I push it back down.
da
Aggiungi la tua risposta
Brittany McCrigler sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 85
