Is there a way to remove the internal memory device?
i have 2 of the same tablet, one has a smashed screen and can't be used. since everything is soldered together i cant just remove the only board from it and put it in the other one. i tried to remove everything from the screen but the battery (soldered to the board) is a soft case and is strongly GLUED to it. (causing damage to the case) is there a memory chip that i can remove to simply swap over the internal memory?
(tablet is a digiland DL701Q)
Questa è una buona domanda?
