Salta al contenuto principale
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Domande Visualizza tutte
Where can I purchase the screws for battery?
My problem here isn't specifically where to get a battery but the screws that are needed. I bought a battery with the screw but there is like a little round part where the screw goes and the screw it had before broke inside it and now i can't the the little round part where the screw goes. Please help?
Update (12/16/2015)
What exactly do I search. I have found iPhone 4 Battery Connector Screw but I need the round part where the screw screws onto. Is there a way to submit a picture?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Jesse Garcia in that case it is not the screw that is a problem but the standoff. Since the screw broke off on the inside of the standoff, there is really no way to remove it. It should not cause an issue for as long as you know that it may be tough to replace the next battery. The upper standoff at the middle of the logic board holds the screw for one side of the dock flex connector cover plate. The lower standoff helps to hold the logic board down and provides the screw for the battery flex connector. That will only be an issue with the battery flex connector during battery removal.
Punteggio 0
You can buy on ebay for like 0.99 I think
Punteggio 0
iPhone 4 does not need battery connector screw to function normally. Just use iPhone without this screw.
Punteggio 0
Aggiungi la tua risposta
Jesse Garcia sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 75
